staight 350 doesn't move
gregjo1948
Post by gregjo1948 » Mon May 15, 2017 4:00 am
I just bought a 350 with a running engine but, the dozer doesn't try to move forward or back. I bought it sight unseen and I'm going on what the seller is saying. He got the dozer when he bought a farm and it has been parked in the barn for 5 years. Said it fired up and ran fine but won't move. Said it's not making any grinding, clunking, squealing, or any other strange noises. Both steering clutches frozen released??? Reverser problem??? Pump??? What's your guess and where do I start looking to fix?
Thanks, gregjo1948
Re: staight 350 doesn't move
Post by Stan Disbrow » Mon May 15, 2017 4:42 am
If it has a reverser, I would look at the isolator first.
jsal
Post by jsal » Mon May 15, 2017 11:17 am
is their oil in the reverser no oil no move !!!!
gregjo1948
Post by gregjo1948 » Tue May 16, 2017 3:22 am
I think that may be it. On my 350B, the isolator sounds like someone hammering on the flywheel. I think the seller would have said something about that noise if it was present. I'll be picking the machine up today and might have a better idea what's wrong with it. I'll post what I determine.
gregjo1948
gregjo1948
Post by gregjo1948 » Sat May 20, 2017 4:16 am
UPDATE.... Got the machine in the shop and checked reverser for fluid.(within lines on dip stick) At about 3/4 throttle,(trans. in gear) shifting reverser from forward to reverse, it doesn't move but, I can hear a change in the engine briefly. I think the change might be fluid direction changing. Guess I'll have to pull the engine and get into the reverser. What do you think I'll find????? Thanks, gregjo1948
jsal
Post by jsal » Sat May 20, 2017 4:38 am
sounds like the drive coupling is gone still need to dismantle to repair done that on my 350 !!
gregjo1948
Post by gregjo1948 » Sat May 20, 2017 4:00 pm
What drive coupling are you referring to? You mean the isolator?
JD430C
Post by JD430C » Sun May 21, 2017 1:28 pm
Think hes referring to the coupler between the reverser and transmission. I have seen them strip out.
Andrew
jsal
Post by jsal » Sun May 21, 2017 5:13 pm
Yes coupler between trans and reverser had one go on my 350 a few years back . jim
gregjo1948
Post by gregjo1948 » Mon May 22, 2017 4:29 am
When it was gave out, would it make any noise when you tried to move forward or back? Mine doesn't sound like anything is happening when I engage the reverser in either direction. I would expect some sort of nasty noise from a stripped spline. gregjo1948
jsal
Post by jsal » Mon May 22, 2017 4:54 am
you have to pull it apart no matter what is the problem no other way to check it !!
JIM
Post by Stan Disbrow » Mon May 22, 2017 5:55 am
The isolators usually make a racket when they go, and the coupler is usually quiet. But, of course, not always.....
You will just have to take it apart from the front to the rear, I am afraid....
gregjo1948
Post by gregjo1948 » Tue May 23, 2017 3:06 am
Don't be afraid Stan!! I'll operate on it soon and it will live to push dirt again. gregjo1948
gregjo1948
Post by gregjo1948 » Wed May 24, 2017 1:11 pm
With the engine removed, can I remove the reverser guts without removing the housing? gregjo1948
Post by Lavoy » Wed May 24, 2017 2:08 pm
No, you will need access from the rear.
