350C isolator CONVERSION - "C" to "D"
Post by Stan Disbrow » Fri Feb 26, 2016 7:20 am
Working now.
If you want to embed it so it shows up in posts, it needs to be unsecured. I find Photobucket is a good place to host photos so you can have them embedded.
But, clicking on a link to open the photos in a new window works ok too.
Post by Lavoy » Tue Apr 11, 2017 8:47 am
Update on this thread. I have flywheels in stock, NOS Deere. Should have hubs back maybe end of next week, and completed kits shortly after that.
cdunn
Post by cdunn » Wed Apr 12, 2017 8:17 pm
Lavoy. I do not suppose that kit will work on a straight 350?
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
Post by Lavoy » Thu Apr 13, 2017 7:28 am
Yes it will.
cdunn
Post by cdunn » Thu Apr 13, 2017 9:56 pm
Thank you, i wii be in touch...
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
Re: 350C isolator CONVERSION - "C" to "D"
Post by Lavoy » Fri Apr 28, 2017 4:03 pm
Kits are about done, should have availability next week. Kit is $2000, and includes NOS Deere flywheel, pilot bearing, isolator and hub for converting 350, 350B, and 350C crawlers to late style rubber torsional isolators.
In the past, there was a disparaging comment made about what I was providing in these kits and their origin. SO, let me be clear. The flywheel is NOS OEM John Deere. The pilot bearing may be name brand import or USA, depends on who I get them from at that time. The torsional isolator itself is made by the EXACT SAME COMPANY that made them for John Deere when they last had them available, and is Made in USA. The splined hub is CNC machined off of the ORIGINAL John Deere drawing, don't ask where I got it. :) All machining, splining, and heat treating are done in USA, period. Hubs are treated to 61 Rockwell if anyone cares. The rivets holding the hub in are OEM Deere rivets.
This is a 8 year long ordeal at least, and I really wish I had been able to do them cheaper. But, to control production to the level I have, and all USA and NOS Deere is expensive, and more so in small quantities.
Post by Stan Disbrow » Fri Apr 28, 2017 4:42 pm
Yay! Especially so as I am 350 C and D shopping. $2k sounds costly until one thinks about how much a 350 C or D lawn ornament is worth because it don't move no more because the isolator is casters up....
nrbsr
Post by nrbsr » Sun May 07, 2017 9:59 pm
I got this kit from Lavoy.
Put it in my 350c last spring and have put it through some tuff hours last year and this year. I've had zero problems and I'm glad I spent the time and money on the upgrade.
Norb
NWJD fan
Post by NWJD fan » Mon May 08, 2017 6:56 am
Unable to see photos. Click on link and get blank screen with access denied. I am signed in.
Post by Stan Disbrow » Mon May 08, 2017 1:38 pm
This board does not host photos, so we all have to use some 3rd party hosting service. The 'access denied' is coming from that particular service - I get it as well.
Farmer John's cousin
Post by Farmer John's cousin » Sat May 20, 2017 3:32 pm
Hey Levoy. That was me over on the JD crawlers tractors Facebook group page asking about these parts. I will let you know if I need them shortly...
Post by Lavoy » Mon May 22, 2017 7:04 pm
Sounds good. I have some reverser parts on hand, and can get others.
Users browsing this forum: No registered users and 35 guests
