Looking for 450c limb risers
ryan71407
Post by ryan71407 » Thu Apr 06, 2017 8:01 am
Need limb risers and exhaust riser for a 78 450c
Can reach me at 337-254-1899
shinnery
Post by shinnery » Thu Apr 06, 2017 8:58 pm
Well 337 area code shows to be S/W Lousiana if it means anything.
vestor_guy
Re: Looking for 450c limb risers
Post by vestor_guy » Sat May 06, 2017 4:44 am
I have a set of 450 limb risers but I am located in SW Missouri.
ryan71407
Post by ryan71407 » Mon May 15, 2017 3:31 pm
I pm'ed you
ryan71407
Post by ryan71407 » Thu May 25, 2017 4:03 pm
vestory_guy check your pms
ryan71407
Post by ryan71407 » Mon Jun 19, 2017 5:00 pm
charlie3933
Post by charlie3933 » Thu Sep 07, 2017 7:02 pm
what are limb risers?
Post by Stan Disbrow » Thu Sep 07, 2017 7:12 pm
They go from the top of the nosecone to the top of the crash cage. Keeps limbs from smacking you in the face. Most of the time, anyway. A different exhaust pipe follows one of the risers (whichever side the exhaust comes out of), or at least is supposed to, to keep it from being bent back into your face by those limbs as well.
B Town
Post by B Town » Thu Sep 07, 2017 7:36 pm
In some areas they are called "sweeps".
StxRancher
Post by StxRancher » Fri Sep 08, 2017 8:33 am
My 450c didn't come with any, but I am going to fabricate some with 2 3/8" pipe. It doesn't seem difficult to do.
B Town
Post by B Town » Fri Sep 08, 2017 11:43 am
Fabricating a pair sounds like a good idea. Try to get the thickest wall possible. The OEM sweeps are hard to get ahold of. The most difficult part will be attaching them to the hard-nose and the ROPS, but making them removable. If you need to bend the pipe, i have blocked one end of the pipe, packed it super tight with silica sand, block the other end, heat and bend. Hopefully the compressed/packed sand prevents the tube deforming too much. Bruce
StxRancher
Post by StxRancher » Fri Sep 08, 2017 3:13 pm
Fortunately I have a hydraulic pipe bender that will bend it. I was thinking of making mount tabs bolted to the nose where I can put a bolt or pin thru them. I will send pics once I get on it.
B Town
Post by B Town » Fri Sep 08, 2017 7:26 pm
Oh Yeah!! The right tool for the job.
B Town
Post by B Town » Sat Sep 09, 2017 3:16 pm
Just for jiggles, look at how deere attaches the sweeps to the hardnose on the 450E series. IMO this would be easy to replicate, yet effective and removable. I think the harder issue is marrying into the ROPS, but following the original 450C design might not be too bad.
