Pammark
Post
by Pammark » Thu Feb 01, 2007 10:56 am
I just bought a 2010 crawler/loader and ran it across some scales on my way home. It weighed in at 6.4 ton. I seen several entries asking about weights.
This dozer has low hours at 1700. I think it is correct because the bucket teeth has little wear as well as the undercarriage. It needs some TLC. It has a right sticking clutch and a broken air cleaner top. The trans was low of hyd oil and when I added some, I seen a small dribble left behind between the tracks. It looks like it is from the bell housing with maybe a dried-up seal behind the throughout bearing and tranny. Is this common? Is there an additive that will rejunvenate the seal?
Mark
JD 2010 Crawler with Loader
fishhawk
Post
by fishhawk » Thu Feb 01, 2007 12:10 pm
old trick i have used is just stick in about a ounce of break fluid, swells the rubber in the seals. fishhawk
wayne
Post
by wayne » Mon Feb 19, 2007 8:37 pm
Hi, You might want to try the Lucac product "hydralic oil booster & stop leak". The web address is;
www.lucasoil.com/products/displayproduc ... 2&loc=show. Soo long an address,however, it will get you to a good product desctiption. Most fully stocked auto parts stores will carry this item. The gallon is the best price and will go a very long way.
Pammark
Post
by Pammark » Mon Feb 26, 2007 3:54 pm
My hyd leak ended up being the hyd cooler line to the radiator. I had to remove the front engine belly plate to see where it came from. Replaced 5 inches of hose and ready to go. Not a seal afterall.
Pammark
Users browsing this forum: No registered users and 47 guests
