Ripper shanks 350C wanted
Hi
I have a JD350C Drott missing ripper shanks. It has provision for 3 shanks and it uses one hydraulic cylinder to operate ripper.
Any ideas where I can buy?
Or where I can obtain the measurements to have them made?
Hope you can help.
Regards
Graeme
gvauto@bigpond.net.au
Hope you can help.
Regards
Graeme
Need pics....... book shows A 3100 ripper used on 350C and that would have 2 cylinders and openings for up to 5 shanks they run about $200 each... Sounds like you have something else again need pics
I recently purchased 2 shanks for my ripper installed on my 350c. Deere had them in stock as well as the spring clips for adjusting them up or down. The cast wedges (about 4 inches long by an inch wide+-) that the spring clips attach too, are discontinued. Although, they are easily cut from an iron bar with one hole drilled and tapped for the clip, so just measurements are all you need. Yes, about 200 each including the hardened tip. I can send you photos and measurements if you want to make some.
backhoe attachment.
backhoe attachment.
Follow up to my comment, my ripper has 5 holes for shanks as Jtrichard noted in his post. As does every deere ripper for 350 and 450s that I have seen.
backhoe attachment.
backhoe attachment.
I wonder if he meant he has a Drott ripper, if there is such a thing.
http://i61.photobucket.com/albums/h53/G ... xlefjf.jpgshinnery wrote:I wonder if he meant he has a Drott ripper, if there is such a thing.
The neat hole size on ripper for shanks is approx 2 1/4inch thick, 5 1/4 long and pin size is 2inch.
cheers
Graeme
HOLLY sheep shit that is NOT OEM for a 350 I will do some looking and see if I can match the measurement you gave ......
It has also managed to add 3 blank pages on this thread.
With that BEAST on the rear you should not need any other counterweight
There is NOW a page 2
Wow how the hell did you find this information. Well done.jtrichard wrote:http://www.hltooth.com/cat_product.php?pid=293
Maybe its a factory ripper.
