question the new sealed rollers
Wanted to ask and see if anyone has tried this. Need to rebuild the front idlers on the 430. Do the new rollers that are sealed for the 350 that can be purchased for around 100 have the correct shaft and bushings that could be used for what I need? I understand I would need to figure out the grease problem, just wondered. Never had a new roller apart yet. Wanted to basically know if buying the new roller and used the parts from it to fix the old would work.
Nope, completely different. Only thing to use on front idlers is OEM replacement.
