injectors
chuck 350 jd
injectors
Post by chuck 350 jd » Mon Aug 15, 2016 12:25 pm
Where is the best place to get injectors for a 1967 John Deere 350b. What is the part # for them and would it be ok to get them off of eBay.
Thanks for your help
shinnery
Post by shinnery » Mon Aug 15, 2016 12:57 pm
Lavoy sells parts, that is how he keeps this site online.
amos
anywhere is good
Post by amos » Tue Aug 16, 2016 4:40 am
Injectors are all over the net. +/- $50.00 a pop. If you're replacing the injectors because you have an intermittent miss before you do so check your valve adjustments on the head. They are adjustable and need adjustment periodically. Be sure to order a new valve cover gasket before you pop the cover off.
Post by Tigerhaze » Thu Aug 18, 2016 2:17 pm
There are some pretty good discussions on this board by Jdemaris about injector and injector replacement if you search for them- some are adjustable and some are "throw-away" when worn.
Users browsing this forum: No registered users and 268 guests
