Where is the best place to get injectors for a 1967 John Deere 350b. What is the part # for them and would it be ok to get them off of eBay.
Thanks for your help
injectors
Lavoy sells parts, that is how he keeps this site online.
anywhere is good
Injectors are all over the net. +/- $50.00 a pop. If you're replacing the injectors because you have an intermittent miss before you do so check your valve adjustments on the head. They are adjustable and need adjustment periodically. Be sure to order a new valve cover gasket before you pop the cover off.
There are some pretty good discussions on this board by Jdemaris about injector and injector replacement if you search for them- some are adjustable and some are "throw-away" when worn.
Users browsing this forum: jimmydiesel and 357 guests
