jd 450d will not move
I need help, dozer was running great. I went from reverse to high and it made a funny sound and hasn't moved since. I pulled the top off the transmission and nothing is moving when you start the engine. Any help is greatly appreciated.
My money is on a broken HLR input shaft due to loose or broken transmission bellhousing bolts. That would also cause no function to the HLR or anything behind it while the engine is running.
That would be my guess. If the HLR is neutral and the input shaft is good with the cover off you will see the clutch drums spinning.Tigerhaze wrote:My money is on a broken HLR input shaft due to loose or broken transmission bellhousing bolts. That would also cause no function to the HLR or anything behind it while the engine is running.
450C Track Loader
291457T
291457T
All you have is engine clutch and HLR input shaft. If the HLR cover is off and engine is running and the part you can see is not spinning, you have one of those two busted.
I guess if there is a silver lining is that both the engine clutch and the HLR input shaft are in the same spot so you will find out either way.
Users browsing this forum: Google Adsense [Bot] and 18 guests
