40C tracks
Loose Tracks
40C tracks
Post by Loose Tracks » Sun Mar 20, 2016 6:27 pm
I have a'54 4 roller and a 5 roller 40C. Tracks on the 4 roller are fair, tracks on 5 roller bad wore out. The 5 roller frame is going to get a restored drive train so I need to do something about tracks. Either pin & bush the 5 roller tracks or find another set of tracks or find enough pads to lengthen the 4 roller tracks to fit. Can anybody help? Also, will 420 tracks fit a 40?
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Mon Mar 21, 2016 6:09 am
420 pins and bushing's are larger than the 40 so you will need the 420 sprocket in order for it to work properly the 420 chan is the same through the 2010. 440 sprocket won't work, different offset.
nothing crawles like a deere
Post by Stan Disbrow » Mon Mar 21, 2016 7:46 am
There is also the option of using JD 350 chain if you cut the teeth off of the older sprocket and weld a 350 rim sprocket onto it. The 350 chain has a different pitch but it fits the rollers and idlers ok.
I mention it because 350 chain and rim sprockets are still available new.
Loose Tracks
Post by Loose Tracks » Mon Mar 21, 2016 11:47 am
I take it that the 40 & 420 sprockets are interchangeable as far as the axle hub?
40U, 40C 4 roller, 40C 5 roller, '56 Mack B61T and a bunch of other Macks
Post by Tigerhaze » Mon Mar 21, 2016 4:08 pm
mapaduke@yahoo.com wrote:the 420 chan is the same through the 2010.
That is only true for early serial number 2010 track links/chain (through s/n 42,000), although the early 2010 has more links than needed for a 420. The track links for later serial number 2010s are the same as for the 350 crawlers, just fewer links.
Loose Tracks
Post by Loose Tracks » Mon Mar 21, 2016 6:28 pm
Thanks for all the info!
Post by Lavoy » Mon Mar 21, 2016 7:17 pm
420 chain is also 2 bolt, 2010 is 4 bolt. Pitch and bushing size is the same though, regarding 2010 under 42,000.
Post by Stan Disbrow » Tue Mar 22, 2016 6:06 am
I suppose I ought to point out 350 is 4-bolt as well.
