I want to do a post mortem on some CA is terrible filters from my 450.
What is best way to get filter out of metal can? I know I could use saws all, but that would get metal in the filter and foul up my post mortem.
Slwbid
How to check filters
Stacy
I would use the saw and then do the research below that line of debris. I have used a body panel cutter on an air gun before. I've also just used a hammer and chisel. Tin snips might work if you can gate a hole cut in the canister first.
- cowboy4996
They actually make a tool to do this.
A quick internet search shows lots of different tools available, from Amazon, Ebay, Summit....etc... most resemble a large tubing cutter.
Perhaps one of the repair shops in your area has one and would do it for you.
Much as I love buying tools, I wouldn't buy one.....Leonard's method has worked fine for me for years.
JD MC JD H JD L JD hit and miss engines
I have the large 'pipe cutter' tool. Very important to have one when racing....
post mortem filders
hey, I like the "score with a hacksaw" idea!
Thanks for all the ideas
slwbid
slwbid
Stacy
