420C Steering Clutches Slipping
jibs1723
Post by jibs1723 » Tue Mar 08, 2016 1:33 pm
After getting my trans all rebuilt and steering clutches cleaned and reassembled I have been using the crawler for a little while now. I have noticed sometimes that the left track will slow down or stop when pushing hard. I checked the throw out bearing for the clutch and it is not riding the fingers holding pressure off the clutches. My question is there any burnishing procedure for these or just use them and they will wear in? The clutch steels were a bit rusty so I sandblasted them all when it was apart and cleaned up the friction disks as well. Everything looked decent and measured in spec when i was putting them together and drives fine unless working hard.
Any thoughts?
John Deere 420C with Loader. Ferguson TO-35 with Davis Loader. John Deere 318 and many more....
Post by jtrichard » Tue Mar 08, 2016 4:49 pm
Any pics with the pack assembled? If not can you put it back together and take a pic or 2 of the pressure plate all tightened down ?Don't worry about shaft alignment of "flexing" the pack... Assembled is the only way to see what might be wrong everything i see here looks fine ... as for cleaning them i have done that as others have and it works great
Post by Paul Buhler » Tue Mar 08, 2016 6:48 pm
What you show looks good. Is there a possibility that the pinion seal is leaking so that you are now getting oil on your refreshed clutches? As JT suggests, a picture of your clutch pack/final assembly may give some clues as well. Having rebuilt my final drives/clutches/brake bands this summer I've learned that there are a number of things that can cause the clutches to slip so you need to figure out what part of the re-assembly needs tweaking/fixing. Best wishes getting it sorted out - we've all been there.
Maybe my thread on my fix will be helpful
http://www.jdcrawlers.com/messageboard/ ... highlight=
JimAnderson
Clutch slip
Post by JimAnderson » Tue Mar 08, 2016 8:41 pm
From the picture posted there seems to be no oil contamination.If you have the stack adjusted (clutch gauge) and the clutch slips you need a
new or rebuilt pressure plate.Lavoy has both gauge and pressure plates. JMHO,JimAnderson
Post by Lavoy » Wed Mar 09, 2016 9:08 am
Pressure plate is weak.
jibs1723
Post by jibs1723 » Thu Mar 10, 2016 12:04 pm
Thanks for all the responses everyone. Unfortunately the weak pressure plate is sounds like the culprit. I know that there is no oil on the clutches as I just finished them and replaced all the seals. I did not have the gauge for adjusting the clutch fingers but I did adjust them so they were all even and i measure them off the the face of the drum. I do not remember what measurement i used. But, i did use the same measurement for both sides and the other side works fine.
Here is a pic of the assembled clutch. Everything looks good to me. Not that I have seen many others haha.
Here is looking at the throw out bearing adjustment. I would think that if i had the clutch fingers any tighter i would have ran out of adjustment for the throw out bearing since tightening the fingers up pulls them further away from the throw out bearing.
Lavoy, can you replace just the springs for the pressure plate? The clutch surface was good and the fingers are in good shape. I would like to replace them if possible. Can the pressed in pivot pin be removed and put back in and welded to hold it? Do you sell just the springs? If not, how much is a complete pressure plate?
Thanks for all the help!
Post by jtrichard » Thu Mar 10, 2016 1:45 pm
From what i can see in your last pic the pack is looking great and as long as you have throw out clearance about the only thing left would plate pressure springs
Post by Lavoy » Thu Mar 10, 2016 4:16 pm
No service parts are available for pressure plates. New ones are $125/each.
JWB Contracting
Pressure Plate Rebuild
Post by JWB Contracting » Thu Mar 10, 2016 9:14 pm
We are trying it get some heavier springs made so we can rebuild the pressure plates. This is a common problem with all deere dry steering clutch machines. Will get them in green deere, 350 and 450 once we get them figured out. My dad is now full time on shop work I'm there almost every weekend.
My dad found a bag of previously sourced springs for a 420 that we installed in a MC last weekend. Much stiffer than what we replaced.
We had a similar problem with a 450 last year and now know it was the pressure plate. Very frustrating re doing work so best to get a replacement pressure plate.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
gregjo1948
Post by gregjo1948 » Sun Mar 13, 2016 5:03 am
I don't know about a 420 but, I think my 1010 requires another clutch disc and metal ring.
Post by Lavoy » Sun Mar 13, 2016 11:14 am
Correct, 1010 has more discs than 420.
Users browsing this forum: No registered users and 204 guests
