That's what I thought. Fortunately the hole is super small and most likely able to be plugged with JB weld. I have searched some of the dismantling yards back east. I only see the JD400's once in a while. Now to wait for spring and all this snow to melt off.jtrichard wrote:I would say gas vs diesel are NOT the same JD shows 5 different #s for gas and NO # and NO longer available for diesel
Up at the elbow that goes into the cylinder head is a large allen socket pipe plug. I wanted to hook up there. The ports would be almost the length of the engine apart. But I just could not get it loose. I put an allen wrench in it and even got a jack handle as a cheater bar. No go after several tries. I was expecting the wrench to shatter or the socket to strip out. Then started wondering about doing it my way instead of what's in the manuals etc. Common sense says to do what you are saying as the hook up like I just did from the JD site seems like it would only heat the middle cylinders. . I don't have all the coolant back in yet. And I just returned from town with NAPA kool for both machines. I was just going out to finish it up as a huge pile of snow and ice fell off the roof 20 feet long right where our path is to the front door is. I need to move it. Thanks for mentioning this. I'll try to spread these fittings apart more.Lavoy wrote:Tank heater will work a lot better if you plumb the top hose into a tee at the temp sending unit.
Users browsing this forum: No registered users and 188 guests
