Getting ready to put the final drives back on and want to fabericate a wrench for adjusting the throw out. I don't have the tall adjusting screw just a bolt and washer in the carrier.
What do you guys use? I thought of using a crowsfoot but it doesn't look like it will have the reach.
MC steering clutch adjusting tool
- mapaduke@yahoo.com
nothing crawles like a deere
Without the tall adjusting bolt, not sure you will be able to get on it. I use cheap 1/2" wrenches, cut the ends off and weld them to small diameter rod and make my own.
A couple points about making these tools. Use six-point not 12-point, then grind off the chamfer on the business end to make 100% hex contact.
SIX point is the best as said by STAN the manStan Disbrow wrote:Hi,
Yes, 12-point tends to not grip all that well, and when on nuts and bolts you would really not want to booger up, you really want a 6-point.
Now, that does come with a bit more trouble lining one up. So, sometimes that can be an issue. But, for sockets anyway, the 4-point drive is offset to the 6-point business end such that if one pulls the socket off and rotate it one flat on the drive it then offers a different alignment.
So....that equates to a 6-point offering the same number of get-it-aligned points as a 12-point.
Users browsing this forum: Google [Bot] and 412 guests
