450 Loader track adjustment
JD450tl
Post by JD450tl » Sat Nov 28, 2015 1:28 pm
Thanks for all of the input. I think, for now, ill leave it alone. I haven't had any track jumping issues (yet). At the rate I use it, it may be a few years or more before it really becomes an issue. The machine is basically a toy, not a money maker. That makes it difficult to justify, especially to the wife.
JD450tl
Post by JD450tl » Sat Nov 28, 2015 1:29 pm
Just out of curiosity, what would a set of chains run for a 450?
Al Swearengen
Post by Al Swearengen » Sat Nov 28, 2015 11:05 pm
JD450tl wrote:Just out of curiosity, what would a set of chains run for a 450?
I got a set of Berco SALT chains and sprockets for around $2300 several years back.
Post by mini kahuna » Wed Dec 02, 2015 5:58 am
if your not having any issues with it and you only use it from time to time I would just use it as it is.
your right.....might be years before you get to the replacement point.
hope I didn't just curse you :roll:
1010 loader
Post by Stan Disbrow » Wed Dec 02, 2015 6:06 am
And, on a 450, the parts are likely to still be available whenever you decide it is time. Unlike some of the older machines.
egeor
Post by egeor » Wed Dec 02, 2015 7:29 am
I pulled a link from each side on my 350 ten years ago no problems.
That machine is used about 100 hrs a year.
68 350 loader
79 350c loader
88 case 580k 4x4
89 ford 2120 4x4
Tedman
Post by Tedman » Wed Dec 02, 2015 9:42 pm
I just bought a brand new full undercarriage (ITR Brand) for my 450C loader and am in the process of installing it. New chains - $1,652, triple grouser shoes - $1,293, track bolts and nuts - $266, sprockets $112 each, front idlers - $489 each. I am almost done putting all the new stuff on and it's been easier that I anticipated. I have a concrete floor and overhead hoist and that has been a lifesaver!
JD450tl
Post by JD450tl » Fri Dec 04, 2015 7:43 am
egeor wrote:I pulled a link from each side on my 350 ten years ago no problems.
That's what I was hoping to hear from someone. This thing doesn't get used enough to justify dropping 3-4k on it
Post by Paul Buhler » Fri Dec 04, 2015 5:40 pm
Been there, done that, meaning having to make a choice. Getting someone's actual experience to consider is very useful. Maybe at some point in time it may make sense to spring for the better undercarriage, but knowing that you can expect yours to hang together for your needs is reassuring. That said, as you know, there are no guarantees. Best wishes. Paul
JD450tl
Post by JD450tl » Tue Dec 08, 2015 7:56 pm
Paul Buhler wrote:Been there, done that, meaning having to make a choice. Getting someone's actual experience to consider is very useful. Maybe at some point in time it may make sense to spring for the better undercarriage, but knowing that you can expect yours to hang together for your needs is reassuring. That said, as you know, there are no guarantees. Best wishes. Paul
I'm sure there are guys on here that cringe at the thought of just "making it work" but, I look at it as, its still one less machine in the junkyards. It is surprising the amount of power these little loaders have
Willie B
Post by Willie B » Thu Dec 17, 2015 6:23 am
I'm starting to like wheel tractors more, and more!
An optimist is usually wrong, and doomed to disappointment. he is unprepared. A pessimist is usually right, delighted to be wrong, and is well prepared.
Users browsing this forum: No registered users and 272 guests
