Offset disk on a 420 C?
Anybody have any experience pulling an offset (Rome) disk with a 420C? I'm wondering how big of a disk I can expect to pull with it. Gonna use it for hillside pasture renovation. It's a future purchase, and I don't want to buy something bigger than I can pull easily. I've got my eye on a 6 foot disk with no wheels.
420C, 5 roller, 62 blade
It should handle that nicely. Seems to me, you can adjust them to varying degrees of cutting.
It's going to be like any other ground breaking operation- what you can pull depends on the ground. An offset disc is a heavy pull no matter what the soil. I'd be inclined to go a little smaller rather than a little bigger. Easier on you and the machine and you'll likely go faster which get's the job done quicker and often gives better results on the soil.
40C, 420C, 1010C-L-BH, Cat D4
Width is not the only factory, what blade size? A 24" blade pulls a lot harder than a disc with 16" blades. Bigger factor is depth and soil type. Here at my place I could easily pull 10' because you can't get it in the ground anyway. At the farm buried to the hubs with my 6' Killefer with 22" blades, quite a pull.
Drawbar hitch.
I'll have to look closer at the disk - it's nothing like we used in road construction - much lighter.
The owner pulled it with a Ford 5000 farm tractor, and at one time, with a 630 JD. If I remember right - the 630 struggled a little with it.
I'd rather have too small than too big, of course.
Thanks for the comments - I'm in the looking/dreaming stage - my pasture has some steep areas, and I'd like to renovate it in a couple of years.
