420C starting issues
I'd try using a gas/oil mixture (chain saw fuel) in a squirt bottle.Turn fuel off from the tank and spray the mixture into the carb to get it started and continue spraying to keep it running for a few minutes to help free up rings that maybe stuck to the lands. This may also help with the low compression. Too much oil will tend to foul the plugs.
420 starting issues
You have gotten a lot of knowledgeable replies but I'll just add my 2 cents. For both of my gas engines that sit for a long time I find it works great to tow start them when they first come out of the shed. Start in a high gear, to turn the motor over slowly, then work your way down through the gears. Saves a lot of wear and tear on the starter and I think you get a stronger spark since you aren't drawing juice for the starter. Do go easy on the choke though. Although if you do flood it just let it "run" with no choke as your buddy tows you around the field or down the road and it will clear itself.
Of course my situation is different from yours since I know both machines were running well when I parked them.
Just a thought that might help.
Re: 420 starting issues
Make sure before towing that the engine isn't seized.Lowly wrote:You have gotten a lot of knowledgeable replies but I'll just add my 2 cents. For both of my gas engines that sit for a long time I find it works great to tow start them when they first come out of the shed. Start in a high gear, to turn the motor over slowly, then work your way down through the gears. Saves a lot of wear and tear on the starter and I think you get a stronger spark since you aren't drawing juice for the starter. Do go easy on the choke though. Although if you do flood it just let it "run" with no choke as your buddy tows you around the field or down the road and it will clear itself.
Users browsing this forum: No registered users and 80 guests
