gearmatic 8a part
notmeu
gearmatic 8a part
Post by notmeu » Wed Sep 09, 2015 7:50 pm
Hello all, I am looking for a replacement brake adjusting nut for a 8a gearmatic winch, it is located on the bottom outside of the clutch/brake side of the winch. It is item number 81 in the manual, part number A1103. I cannot find one for sale as a aftermarket part, can anyone help out?
pop pop
Post by pop pop » Wed Sep 09, 2015 11:04 pm
i might be able to make you a copy. i have the side off my winch right now so tomarow AM i will look and see.
notmeu
Post by notmeu » Thu Sep 10, 2015 5:18 am
Thanks pop pop, It looks pretty simple to make. But there is so much rust and its hard to guess what the actual measurements should be.
pop pop
Post by pop pop » Thu Sep 10, 2015 10:59 pm
durn, i got in a sweaty wrestling match under an old mustang today and by the time i won i was too beat to follow up on what i promised,,
i'll do it fri AM.
Howard Yoder
Post by Howard Yoder » Fri Sep 11, 2015 9:46 am
Have you tried paccar I got one off of them about 10 years ago
notmeu
Post by notmeu » Fri Sep 11, 2015 4:48 pm
Actually I didn't for this part, I tried on a few other parts and they were not available, they did say that they could release the drawings to me. I'll try them on Monday morning.
Post by Paul Buhler » Fri Sep 11, 2015 8:18 pm
Tom:
On my winch it appears that this adjuster has been replaced with a piece of properly sized threaded water pipe (nipple) that has a doubled washer welded inside as a "bottom" for the shaft to rest upon. There are a couple of slots cut into the bottom so that a lever can be inserted to turn it up or down as needed. Not fancy, but it works. Pop Pop's offer sounds really good. Good luck Paul
pop pop
Post by pop pop » Tue Sep 15, 2015 12:07 am
pauls description is pretty accurate as that is what mine appears to be also.
i tried to measure it but is in a pretty tight spot.
the winch is on my bench and i cant roll it over without lifting it and my engine hoist is on the other side of the shop right now.
but i looked at it 3 times already,,, hope your a patient man.
i can probably get some measurements soon.
notmeu
Post by notmeu » Tue Sep 15, 2015 10:25 am
No problem pop pop, I've been struggling with trying to get the clutch spider piece off of the clutch side of the winch. Hopefully if time permits tonight, it will be rosebud tipped torch night!
Post by Lavoy » Tue Sep 15, 2015 1:57 pm
I resembles a pipe nipple, but isn't. It is standard NF thread, counterbored for the spring, and a slot milled in the bottom like a screwdriver slot. I had some made a long time ago, let me see if I have any left.
notmeu
Post by notmeu » Tue Sep 15, 2015 3:08 pm
Lavoy wrote:I resembles a pipe nipple, but isn't. It is standard NF thread, counterbored for the spring, and a slot milled in the bottom like a screwdriver slot. I had some made a long time ago, let me see if I have any left.
Sounds good lavoy, let me know!
Post by Lavoy » Tue Sep 15, 2015 7:26 pm
Send me an e-mail so I don't forget. If I don't have any new ones left, I need to get another batch made up, will just need to find my pattern. Might take a little longer if you can wait.
