Broke down a bought a dozer
I did try to find an affordable (to me) JD but had to settle for an early 50's Cat D4. Once I get it home I'll get a picture up so you all can laugh at me!
Rick
Rick
Is it going to be of more use to you than a Gen. Creighton?
- cowboy4996
Nothing wrong with a good ol' D4... growing up on the ranch we had a MC and a D4 7U series. Each had a job to do, and both served their purpose well.
I have the MC and my uncle has the D4 on the ranch. I may have some books on the D4 if you need some info, depending on the series you have.
JD MC JD H JD L JD hit and miss engines
Schennery: Lot more now
! Don't need a tank....but it would be fun!
Coyboy: It will be delivered sometime later this next week. I'll get the serial number and figure out what year/series it is then. One another note later this month I'll be out in the Grangeville ID area later this month. Taking the MIL out to see her sister. How close are you?
Rick
Rick
- cowboy4996
- cowboy4996
OK thanks. I don't have any of the manuals yet. And yes. It' an electric start pony on it. Interestingly enough it uses the same carburetor that JD used on the pony motor on the R.cowboy4996 wrote:Nice!! That's what we had on the ranch.
Is the fuel tank behind the seat or beside you? Does the pony motor have electric start?
If you need any tech info, I'm pretty sure I have the service manuals and a parts manual, and I could pass on the info.
Wayne
Rick
You typed the post title wrong. Let me fix that for you:
I Bought A Down Dozer And (am) Broke
At this point, I am afraid to use a smiley.....
And, this isn't a Deere vs Cat comment. It is, unfortunately, a Dozer Truth...
Stan Disbrow wrote:Hi,
LOL I've been told that a few times! The pony carb and steering brakes need work. Undercarriage is about 70-75%!! Main engine runs. Could have do a lot worse for 2200. Wife is giving me heck cause it has a little rust.....
Cowboy, forgot, Side fender mounted tank, 1947.
Rick
- cowboy4996
Well, that D4 surely sounds worth going broke on. Especially if that 75% is 'our' measurement and not a 'sellers' version (which means the tracks stay on for 3 out of 4 turns)....
Rick
Sounds like a great deal to me.
I always like the 'ran fine when we parked it' line. I translate that to 'was running until this point right here'...
