440 ICD Questions
GaCatskinner
440 ICD Questions
Post by GaCatskinner » Wed Sep 02, 2015 3:11 pm
Howdy y'all. I'm new here and have a few questions about a 440 I acquired. It needs quite a bit of work but I did load it on the truck under its own power. It's sort of a Frankenstein, someone removed the original seat and replaced it with the operator's station from a 350. My first question (of several I'm sure) is what is the hydraulic pressure supposed to be on this machine? Oh and how do I determine the year?
rustywheel
Post by rustywheel » Wed Sep 02, 2015 6:30 pm
Google "John Deere 440 IC" and select the tractordata website. It'll list the serial numbers by years.
notmeu
Post by notmeu » Wed Sep 02, 2015 7:27 pm
I'm pretty sure the 440 hydraulics are the same as the 420s, that being said it's 1000 psi.
Post by Stan Disbrow » Thu Sep 03, 2015 3:48 am
Yes, 440 same as 420.
For the serial numbers by year, forget Google. Just go to our own FAQ section. :)
http://www.jdcrawlers.com/messageboard/ ... c.php?t=38
GaCatskinner
Post by GaCatskinner » Thu Sep 03, 2015 8:08 am
Thanks for the replies. Unfortunately mine is missing the serial number tag on the Bell housing. Is that info stamped anywhere else on the tractor?
notmeu
Post by notmeu » Thu Sep 03, 2015 8:16 am
GaCatskinner wrote:Thanks for the replies. Unfortunately mine is missing the serial number tag on the Bell housing. Is that info stamped anywhere else on the tractor?
From a previous discussion somewhere here on the board, there is a number stamped on the motor by the hydraulic pump that can be used to obtain a new serial tag from your local JD dealer. They may be able to tell you the year by doing this. I am missing my tag also, but I know the year of my 420. I never made the time to make it to the dealer for a new tag yet but someday I will.....
Post by Stan Disbrow » Thu Sep 03, 2015 10:49 am
Well, all I can think of is looking thru the parts catalog and matching items you have against serial number breaks. That is how I figure it out for these old girls when their tags have moved on.
DukeofDeere
Post by DukeofDeere » Thu Sep 03, 2015 11:00 am
Your 440 ICD IS A '59 OR '60.
Only built for 2 yrs.
Happy wrenching,
Duke
pop pop
Post by pop pop » Thu Sep 03, 2015 11:46 pm
there are little telltail differences, is the throttle lever in the center or side of dash?
GaCatskinner
Post by GaCatskinner » Fri Sep 04, 2015 5:24 am
Throttle is on the left side.
pop pop
Post by pop pop » Sat Sep 05, 2015 10:35 pm
lookin like a 59.
it does have 5 FWD gears right?
GaCatskinner
Post by GaCatskinner » Sun Sep 06, 2015 6:43 pm
Yeah it has the 5 speed. It also has a reverser but it is non functional.
pop pop
Post by pop pop » Mon Sep 07, 2015 11:09 am
another way to pinpoint the year is by decal placement and grille material, pretty sure yuo've got a 59.
what else do you want to know.
GaCatskinner
Post by GaCatskinner » Mon Sep 07, 2015 6:00 pm
Any idea about hourly fuel consumption?
Post by Stan Disbrow » Tue Sep 08, 2015 5:46 am
Couple gallons an hour.
Users browsing this forum: Google Adsense [Bot] and 15 guests
