undercarriage swap
danny G
undercarriage swap
Post by danny G » Thu Aug 20, 2015 2:19 pm
I have an early model 2010 . Found a late model near by with a better undercarriage but does not run and has had a few parts sold off of it he wants 1000$ and will deliver it.. can I swap entire undercarriage?. Has other things I need like front skid plate and floorboards . Any thoughts..... thanks
2010 loader backhoe... Massey 180... white 4x4 w/ loader ... JD amt 626 ...
Post by Tigerhaze » Thu Aug 20, 2015 2:31 pm
All you need to swap is the sprockets when you swap the tracks (i.e. the early and late S/N sprockets are different)- all else should interchange. Keep in mind that undercarriage wears as a unit so depending on condition you may want to swap other undercarriage parts as well.
$1000 is a cheap parts machine so if you can get the whole thing it may be well worth it to have a spare HLR and engine. You are definitely getting your money's worth with the undercarriage because you can't even get late-model sprockets to the undercarriage swap anymore unless you luck onto a late model parts machine like you did.
danny G
Post by danny G » Thu Aug 20, 2015 2:45 pm
Thanks . I would try to change everything over. I want to run whats on it till they won't go anymore. .. ok so it could be done thats what I was after. Thanks
shinnery
Post by shinnery » Thu Aug 20, 2015 8:41 pm
Something to think about, would it be easier to put your engine in the other dozer? Just an idea>
danny G
Post by danny G » Thu Aug 20, 2015 8:52 pm
I thought about it but . It doesn't have a loader or left steering clutch is gone and radiator .a few other things ..it was a part machine for a bit .. but it has a lot of stuff I need .like skid plat and floor boards. Undercarige is most important to me ..engine only good for part's.. ben sitting a wile ..The rest of my crawler is ok . A few minor things
Post by Stan Disbrow » Fri Aug 21, 2015 6:32 am
Sounds like a terrific deal there. Do yourself a favor when you get it. Shove it under a pole barn and set it on boards. Keeps the rust formation down.
Or, given it is pieces of a sort to start with, plop it on boards and then build a simple pole barn over it! :P
Users browsing this forum: No registered users and 315 guests
