450B Clutch Bell Housing
Jimmy450b
Post by Jimmy450b » Fri Aug 07, 2015 2:51 pm
I'm replacing the steering clutches on my dozer but I noticed the 2 top bolts that attach the transmission to the clutch housing are broke, the 2 bottom bolts are alright, I can get the left bolt out but no luck with the other one on the right side. My question is will it be ok with 3 bolts holding it? I also found that the both frames are cracked which is probably what caused the bolts to break. I hate to have to pull the engine and housing but I will if it's going to cause more trouble down the road.
LeonardL
Post by LeonardL » Fri Aug 07, 2015 6:15 pm
This remaining bolt? Is there enough of it showing so you could weld a nut on it? If not can you get to it and drill it and then try an easy out?
You really need all of the bolts to make your machine as strong as it should be. It would mean a lot of work but it would be worth it in the long run. It also makes your machine worth more if these things are fixed.
Jimmy450b
Post by Jimmy450b » Fri Aug 07, 2015 6:29 pm
LeonardL wrote:This remaining bolt? Is there enough of it showing so you could weld a nut on it? If not can you get to it and drill it and then try an easy out?
Yes I got the left one out by welding a nut on it, not enough showing on the other one to do that, tried drilling it, hard to get any leverage on a drill, close quarters but I will try again before I have to pull engine and housing, thanks.
Scottyb
Post by Scottyb » Fri Aug 07, 2015 8:43 pm
Somewhere in the archives on this forum, I read about inserting copper pipe into the hole up to the end of the broken bolt and, then carefully arc welding inside the pipe until you build it out enough to attach a head on it. I have not yet tried this myself but I will when I am in your situation. Someone here might be able to offer more on this technique.
backhoe attachment.
LeonardL
Post by LeonardL » Fri Aug 07, 2015 9:01 pm
This is a good idea. Although I have not done this myself I have heard of it being done.
There is also an electrode ( rod ) available at most welding supply stores that is made for this purpose. The rod is designed so the flux actually builds out to the side of the hole and then the center is where the metal is built out. It takes a couple of times of chipping the flux away to get it out far enough. It depends on how deep the hole is to get it built out enough to get a nut welded on. I have used this product and it works great. Also the heat from the welding process will help loosen the the threads on the broken bolt.
Post by Stan Disbrow » Sat Aug 08, 2015 4:38 am
And, when drilling, remember to use left-handed twist drils. Not the usual right-handed ones. Quite often the drilling loosens the bolt shank before using the extractor. ;)
pop pop
Post by pop pop » Sat Aug 08, 2015 5:56 am
yes you need all 4 bolts to prevent breaking the next weakest part.
we have become extraction experts, haven't we?
there are at least 39 ways to do it.
here is another, you may have already known about.
clean it up, heat it up,quench it with PBblaster. doing this may help in lossening it for the "e-z-out".
also, may be able to smack it with a punch.
lightly tap on the casting too.
curse it, :twisted: :shock: :roll:
make yourself a drill bushing to maintain center,,,, a really long bit might get your drill in the right position.
a mini dremel with a carbide bit...?
have i hit 39 yet... :wink:
where are you located? i'll bring beer.
Post by Stan Disbrow » Sat Aug 08, 2015 12:28 pm
You missed 'juice'. A 50/50 mix of ATF and Acetone. Works better than Blaster. ;)
Edit: why in heck did Aw Toe Kerrect turn ATF into ATH? Never even heard of ATH..... (?) (!)
Nice modern technology. And, what is worse, I helped to create it! :P
Users browsing this forum: No registered users and 193 guests
