Hello all
I ran my jd440icd out of fuel. When I added fuel and got it running ithe engine did not rev up to normal operating seed. I noticed that the fuel pump was leaking. Could this be the issue? Is there a way to hook up an electric pump? Is there any one that has done it already?
Engine does not have enough power
53 series Detroits will suck air at the fuel pump seal and run like crap ....if the pump is leaking then you may be getting air ....put a new shaft seal in they are a very easy pump to work on
Users browsing this forum: No registered users and 248 guests
