Frame break on 450 e
I recently looked at a 450 e for sale and on the right hand side above the blade raise cylinder the frame was cracked. Is this a common problem and how hard of repair is it to do. Thanks in advance
- drewparsons
not that I know all that much, but I would think if the crack was in line and not jaunting/offset, you could grind a V at the crack and weld it. grind one inch further at the beginning of crack and fill with weld, grind weld flat with surface, check for holes, if no holes primer and paint. If there are hole, grind them out and fill in with weld.
