pippess
Post
by pippess » Sun Jun 21, 2015 10:40 am
so i got a donor motor for my crawler from a 2010 row crop 3 wheel tractor when i pulled the motor from wheel tractor i noticed the clutch and pressure plate was different .So the wheel tractor had a extra spline on the clutch it seems to run the PTO on the wheel tractor . so when i pulled the crawler motor i do not see that extra spline on shaft of trans ?????. so got anew clutch and pressure plate and it came with that extra spline confused that spline is not on the crawler so took that spline off new pressure plate and put motor in and it seems like pump in bell housing is not working . think i mite of missed something
i just ordered my service manuals but was looking for sum more knowledge Thanks guys trying to add pics .
![Image]()
Post
by jtrichard » Sun Jun 21, 2015 10:59 am
here is how you post pics
http://www.jdcrawlers.com/messageboard/ ... hotobucket ...... only one shaft/spline on crawler with HLR does anything work/move? ....HLR uses a different pressure plate .. did you set the finger height? do you have any free play in the floor lever?. Still dont know if yours is loader or dozer????
pippess
Post
by pippess » Sun Jun 21, 2015 6:16 pm
jtrichard wrote:here is how you post pics
its a loader jt no nothing moves or works i got a kit for a 2010 crawler and i set the free play but still have a lot of free play .so my ? is does any of the clutch and pressure plate work off of sum kind of pump because i have no fluid coming out my trans line . i will try the photo bucket.Thanks
Post
by jtrichard » Mon Jun 22, 2015 12:02 am
some thing wrong in clutch as the loader has a separate pump on the rear for the loader hydraulics and it is direct drive from the main input shaft of the trans so if the main shaft is NOT turning NOTHING is going to work ... sounds like you have the wrong clutch ....WHY did you replace it ? that clutch should never have hardly have any wear on it as it is not really a clutch in the normal sense of things it is a cold start trans disconnect ONLY
When you say " but still have a lot of free play" free play where and on what?
Users browsing this forum: No registered users and 315 guests
