crankshaft flange ?
drewparsons
crankshaft flange ?
Post by drewparsons » Tue Jun 16, 2015 8:10 pm
I have a 1970 JD350 loader with reverser, the engine locked up shoertly after I bought it, so I bought a reman engine, as I was about to swich the back plate, because it looked different, I noticed that the crankshaft rear flange on my old one had a 1/4 inch ring or wear mark, and that it was different than the new reman one..the new reman one is just round, no grooves. I measured both and they both measure the same?? can someone help me out here, [/img]
drewparsons
crankshaft?
Post by drewparsons » Wed Jun 17, 2015 9:51 am
Well, okay, let me put it into a question. Does anyone know whether this difference will affect anything? I would like to get my loader back together soon. And yes I have the manuals, in fact I have every manual for the loader and none mention a difference in cranks.
drewparsons
crankshaft?
Post by drewparsons » Wed Jun 17, 2015 12:57 pm
Okay, called the company that sold me the engine, so here is the answer that no one seemed to be able to answer, lol...The grooves are not suppose to be there, even though they looked like they are machined that way. The rear main seal apparently causes this groove in machines this age. When they reman an engine that has this type of wear, they put a 1/4 inch sleeve on the flange to fill in.
Thanks everyone :) next time I will ask a question that someone can answer. lol
Post by Stan Disbrow » Wed Jun 17, 2015 2:07 pm
Ah. Good. That was what I was thinking, but did not *know*. So, I was letting someone else answer you. I follow the board a few times a day, but many only check every few days or so.
drewparsons
Post by drewparsons » Wed Jun 17, 2015 3:24 pm
thanks Stan, yeah I was really worried at first because it looked like it was machined that way, and I had paid $$$$ for the motor and after days of working by myself to remove it from the loader, I was a little crushed, lol...but luckily all is well..i will post a pic as soon as I learn how..
Post by jtrichard » Wed Jun 17, 2015 3:55 pm
THIS will help you with posting pics http://www.jdcrawlers.com/messageboard/ ... hird+party
drewparsons
Post by drewparsons » Wed Jun 17, 2015 5:11 pm
okay, I went out and looked again, and I just find it hard to believe the indents are not machined...I am downloading pics, so I want everyone to chime in..
drewparsons
pics
Post by drewparsons » Wed Jun 17, 2015 6:01 pm
Image[/img]
drewparsons
Post by drewparsons » Wed Jun 17, 2015 6:03 pm
drewparsons
Post by drewparsons » Wed Jun 17, 2015 6:04 pm
drewparsons
Post by drewparsons » Wed Jun 17, 2015 6:09 pm
drewparsons
Post by drewparsons » Wed Jun 17, 2015 6:10 pm
drewparsons
Post by drewparsons » Wed Jun 17, 2015 6:17 pm
the new engine..notice anything different
drewparsons
Post by drewparsons » Wed Jun 17, 2015 6:23 pm
had to post a picture of my baby :D
LeonardL
Post by LeonardL » Wed Jun 17, 2015 7:36 pm
Okay, I haven't posted here in a very long time but I feel like I needed to comment here.
What you are looking at is a removable wear ring that is installed onto the crankshaft so that the Rear main seal doesn't cut that groove directly into the shaft itself. When you purchased an old style seal it would come with a new wear ring. You simply cut the old ring off and installed the new one giving you a brand new wear surface. Sounds simple enough but reinstalling those new rings could be difficult at times. Deere has long sense gotten rid of that system and now you get a all in one seal and ring set combined into one piece. You then need a special rear main seal installation tool to install this new style seal as an all in one piece. Without the tool you can forget it.
Your new or re-man engine has no "Old Style" ring installed. It looks to me as if it was intended to have the new style seal installed. I hope you either installed the new style seal or had an old style with a new ring to go onto your crank shaft. I don't mean to muddy your waters but I felt I needed to say something.
Other than that your machine looks awesome and you did a great job on the restore. Hope this clears this up a bit and I'm sorry you didn't get an answer to this question a while back.
Users browsing this forum: Google [Bot] and 28 guests
