Crawler Bling.A Harley muffler on an MC? How about a Thrush?
kilohertz
Post by kilohertz » Tue Jun 09, 2015 10:44 am
Tried to find a decent size small muffler for the MC, went to all the usual AG stores, finally found one that fits with an adapter, into the original stuck, cutoff flange piece, and it works fine, but is just a plain old muffler. Then I remembered that I had a set of Harley mufflers from my motorcycle riding days, and thought I would see if it would fit, and it's perfect! :D 1.75" ID goes right over the adapter, and it is quieter than the AG muffler. So what do you think? Ag or Harley muffler. We will be restoring and painting the machine this summer, original color scheme. Too much bling? :roll:
Cheers
1952 MC
1965 JD350 outside blade
1968 JD350 Drott 4 in 1
1981 JD450C with 6 way blade and ripper
1965ish 710 green tractor
1978 212 garden tractor
2003 F525 circus mower
shinnery
Post by shinnery » Tue Jun 09, 2015 4:08 pm
Looks good to me, quiet is great.
Post by Stan Disbrow » Tue Jun 09, 2015 5:57 pm
That Harley muffler looks like a CAM to me. Crawler to Air Missile! :P
Post by jtrichard » Tue Jun 09, 2015 8:12 pm
BLING looks GREAT :D :D
pop pop
Post by pop pop » Wed Jun 10, 2015 7:34 am
considering I've seen JD parts on a Harley,, it's justified.
:) watch out thou,, if it starts dripping oil after you park it you'll have to change it back. :roll:
p.s.-what is that in the background? a Polish tire swing?
kilohertz
Post by kilohertz » Wed Jun 10, 2015 8:22 am
pop pop wrote: if it starts dripping oil after you park it you'll have to change it back. :roll:
Well it's dripping antifreeze but that's another story for the tech forum...
No, it's not a Polish tire swing, but a carefully balanced anti-resonant pole damper for my wind turbine tower. The spare ATV tire coupled with a long chain was just the right weight to damp out a harmonic at low wind speeds, it worked and I haven't put in a more permanent solution yet. :roll: Too many crawlers to tinker on. :D
Cheers
1952 MC
Post by Stan Disbrow » Wed Jun 10, 2015 11:51 am
M is Thermo Siphon, so no water pump. Just two hoses and the radiator.
Hmmm. Polish dampener, eh? Temporary Measure, you say?
Well, one of my quotes is "There is nothing quite as permanent as a temporary measure.".... True. So true.....
In this case, it goes along with If it ain't broke, don't fix it....
:P
kilohertz
Post by kilohertz » Wed Jun 10, 2015 12:01 pm
Stan Disbrow wrote:Hi,
Hi Stan,
Thanks, yes, pretty simple...but the leak is coming from a crack in the head, which has been repaired at one time, on the front of the head, vertical. It looks like it has been welded, shiny gold color smooth weld, but it's leaking underneath that. Tried some Iron Tite last week and it seems to be helping, worse when it's cold and once it warms up, seems to stop. I don't know how much that substance will move around without a water pump. It is a thick liquid.
cheers
1952 MC
Post by Stan Disbrow » Wed Jun 10, 2015 12:05 pm
Yeah, the crack closes up when warm. Check you have a Zero Pressure and vented cap in the Rad. Should be No PSI on an M, and they often get more modern caps, which slows the thermosiphon and, in this case, would make the leak worse....
kilohertz
Post by kilohertz » Wed Jun 10, 2015 12:09 pm
And here it is after I removed the old battery bracket from the fender, relocated the battery to it's original spot, and mounted the hood and took off the Jason goalie mask. Looks pretty good for 60+ years old. Waiting for the manuals to arrive then get into the steering clutch adjustment...and that's about it.
Cheers
1952 MC
kilohertz
Post by kilohertz » Wed Jun 10, 2015 4:58 pm
Found this in the shop, a Thrush glass pack...same fit, little bit louder as it's a glass pack, but you can really hear the pop pop now.
Cheers
1952 MC
Post by Stan Disbrow » Thu Jun 11, 2015 5:59 am
There you go! Cherry Bomb! Classic! ;)
You need to add some flex pipe to the end, though. We all know Cherry Bombs have to be used with Flex Pipe. It is a tradition! :P
Hey! Red and Green. Hang a wreath on the grill and call it a Christmas Ornament!
Post by Paul Buhler » Mon Jun 15, 2015 8:28 am
Mine came with a Cherry Bomb - no longer red, but it still works. While it has a stack flap, I keep it covered with a can when parked to keep the rain and snow out of the engine. Have fun with your machine.
lonnie collier
Post by lonnie collier » Wed Jun 17, 2015 1:43 pm
Harley parts and john deere parts are almost in the same neighborhood price wise.jd stuff is a hair more upscale.
