JD 350 Identification
Rickeo2
Post by Rickeo2 » Mon Apr 20, 2015 3:46 pm
I bought my Dads 350 a few years ago, and there has been some debate over exactly what year and model I have. The serial number by the seat is T4F3D 100259T, Where should I look to find more info? Thanks for your help Rick
Post by Stan Disbrow » Mon Apr 20, 2015 4:05 pm
There are serial number lists in the FAQ section. Also, the magic decoder pin is there as well. To save you having to wade thru that section, I have decoded it for you:
T tractor
4 JD350
F Crawler Dozer
3 Diesel
D Directional Reverser
100259 Serial Number, made in 1969
T Dubuque Iowa Plant
Rickeo2
Post by Rickeo2 » Mon Apr 20, 2015 4:27 pm
Thanks for the help....
NWJD fan
Quick and dirty 350 model identification
Post by NWJD fan » Mon Apr 20, 2015 5:37 pm
If the reverser control is on the LH side of the instrument cluster it is most likely a straight 350.
If the reverser control is mounted on the battery box and there are 2 small hydraulic cylinders under the seat it is most likely a 350B
If the reverser control is on the battery box and there is hydraulic manifold under the seat mounted on top of the transmission with 2 valve actuators sticking out the front that are attached to the steering linkage it is most likely a 350C.
There are exceptions to everything but this will give you a fair idea with a quick look.
Rickeo2
Post by Rickeo2 » Tue Apr 21, 2015 4:59 am
The reverser handle is on the left side of the counsel. It must be a straight 350 then. Thanks again for all your help.
JD 350 crawler w/ gaffner boom
jsal
Post by jsal » Tue Apr 21, 2015 6:11 am
I have one with the same numberT4F3D 0388075 1966 vintage.
jim
Post by Lavoy » Tue Apr 21, 2015 10:02 am
That serial number should be a 69 straight.
Users browsing this forum: NevadaKid and 212 guests
