440 6way hydraulic blade
gregjo1948
Post by gregjo1948 » Mon Mar 30, 2015 4:17 am
Will a 6way hydraulic blade with frame and cylinders from a 440 mount on a 1010 without altering or fabricating it to fit? Thanks, gregjo1948
Post by Lavoy » Mon Mar 30, 2015 7:43 am
I believe it will for the most part. I did it the other way, and had some small issues. Also it lifts too high and hits the grille.
gregjo1948
Post by gregjo1948 » Mon Mar 30, 2015 8:01 am
Thanks Lavoy!! I'm looking at it to buy and it has 3 control levers which seems like that could keep your right hand real busy if you use your right hand to steer right also. gregjo1948
Post by Lavoy » Mon Mar 30, 2015 1:42 pm
That's a little odd, normally two left hand levers on their own valve for angle and tilt, and then the crawler hyd on the RH for lift.
wizner85
Post by wizner85 » Sat Apr 11, 2015 12:43 pm
Good to meet you Greg. I appreciate the Business. Make sure you post some pics when it is done.
440 ICD 64 blade & 8a gear attic winch
440 ICD 831 loader with scarifier and weights
420 62 blade 3pt
Looking for 24 scarifier and 440 log arch
gregjo1948
Post by gregjo1948 » Sun Apr 12, 2015 4:05 am
wizner85 wrote:Good to meet you Greg. I appreciate the Business. Make sure you post some pics when it is done.
I'd be happy to post pictures but, I don't know how! gregjo1948
Users browsing this forum: No registered users and 180 guests
