440 6way hydraulic blade
Will a 6way hydraulic blade with frame and cylinders from a 440 mount on a 1010 without altering or fabricating it to fit? Thanks, gregjo1948
I believe it will for the most part. I did it the other way, and had some small issues. Also it lifts too high and hits the grille.
Thanks Lavoy!! I'm looking at it to buy and it has 3 control levers which seems like that could keep your right hand real busy if you use your right hand to steer right also. gregjo1948
That's a little odd, normally two left hand levers on their own valve for angle and tilt, and then the crawler hyd on the RH for lift.
wizner85 wrote:Good to meet you Greg. I appreciate the Business. Make sure you post some pics when it is done.
I'd be happy to post pictures but, I don't know how! gregjo1948
Users browsing this forum: Google Adsense [Bot] and 47 guests
