new 1950 mc
johndeere4402-53
new 1950 mc
Post by johndeere4402-53 » Sat Apr 04, 2015 4:19 pm
picked up and mc this weekend needs a couple little things and then where probaly going to work this one
johndeere4402-53
Post by johndeere4402-53 » Sun Apr 05, 2015 7:10 pm
72 views and noone can say anything? whats the deal with the different frount idlers? is there floor boards in mcs? Is adjusting the clutches the sames as 440s?
johndeere4402-53
Post by johndeere4402-53 » Mon Apr 06, 2015 4:03 am
The track adjuster on left side is the 430 style
johndeere4402-53
Post by johndeere4402-53 » Thu Apr 09, 2015 6:47 pm
welp got here torn down to the transmission to bell housing need some steering clutch adjustment and bushings made the main pressure plate needs replaced and main throughout bearing as and i think where going to throw a quick coat a paint when going back together and it should look fine. will post pics soon
johndeere4402-53
Post by johndeere4402-53 » Sun Apr 12, 2015 7:19 pm
shinnery
Post by shinnery » Sun Apr 12, 2015 8:21 pm
It just needs a bit of superglue on that one clutch finger and it will be as good as new.
Post by Lavoy » Sun Apr 12, 2015 11:30 pm
And maybe a new throwout bearing! :lol:
johndeere4402-53
Post by johndeere4402-53 » Mon Apr 13, 2015 4:04 am
Yep its one of those thing that let me down out in the middle of the woods if i hadnt pulled the engine how hard are the final part to get cause on shaft has some play in it
vtjoe
your clutch
Post by vtjoe » Mon Apr 13, 2015 7:05 am
the correct clutch adjusting tool is a must for new clutch work, as they must be adjusted after bolting up to flywheel
Lavoy (Administrator here) has them
1957 420C four roll since 1982
Post by Lavoy » Mon Apr 13, 2015 7:35 am
Both shafts on the final drive have shims to adjust them, you might be able to just reset the preload.
johndeere4402-53
Post by johndeere4402-53 » Mon Apr 13, 2015 12:49 pm
We have the adjustment tool. Was hopeing that the dogs would work off the pressure plate in the finals but I need to look
johndeere4402-53
Post by johndeere4402-53 » Tue Apr 14, 2015 6:54 pm
So i didnt have a pressure plate. Whats the part number on a new one? and i heard the m tractor 40c -440 gas pressure plates will work? is that true? i need the truth in can find anything for sure in writing.
Also can you still get seals and stuff for the finals? going to tear into both to make sure there good cause there both leaking oil.
Post by Lavoy » Wed Apr 15, 2015 8:28 am
I have the parts you need for both.
johndeere4402-53
Post by johndeere4402-53 » Fri Apr 17, 2015 10:05 pm
so is there any seals in the rollers and frount idlers of the mc? by looking at the parts breakdown i dont see any. Also i ordered a pressure plate tonight going to you the steering handle/brake band shaft outta our parts 440 to replace our cause it the shaft thats wore on the handles not so much the bushings.
johndeere4402-53
Post by johndeere4402-53 » Sat Jul 18, 2015 9:43 am
Well got it tore down going to need all new transmission bearings(or a good old one) center torque tube and final bearing main shaft for either 40 or mc cause i got one of each. Someone used extra bearing for a spacer
https://goo.gl/photos/BGERqRTnNtJn9g4p9
https://goo.gl/photos/BZD8YFifQDBKcuQ29
https://goo.gl/photos/bzAwmJJ7XHVEmaUz8
https://goo.gl/photos/31XhrazPBq25TS1v8
https://goo.gl/photos/PoJzXZFpf8ZNV8Ki7
Users browsing this forum: Google Adsense [Bot] and 164 guests
