Gearmatic WinchDrum 8A Questions
I picked up a 1960 440IC crawler loader last Summer. It had sat a while and the engine was stuck a little. Got it free but not running yet -needs ignition system service.
This crawler has a Gearmatic Co. Ltd WinchDrum Model 8A SN 9382 winch on it that is missing the controls. I am a little nervous about what I might (or might not ) find when I take the winch apart as the bolts in the covers are appear to be several decades newer than the winch.
Would this winch have had hydraulic controls? Are they operated from tractor hydraulic system or from a self contained system? Would anyone have a parts and/or manual in digital format that they would share?
Thanks in advance.
Thanks in advance.
Dennis
1955 40C, 1957 420C, 1960 440IC, 1952 MTW, 1950 M, 1960 Mack B-30
They are hyd control, basically a dual opposing master cylinder setup, hard to find unfortunately.
- Paul Buhler
Here's a link to my Photobucket account (Click on the picture) where there are other pictures of this controller that another member shared with me a few years ago. I'm sorry I don't remember who this was, but hopefully he can chime in and answer any questions that arise. I'm not a Photobucket wizard, so you'll get access to more pictures than you may want. I'll figure this out better later.
I fabricated controls for an 8A winch but lost the pictures when I got my new computer. It's really quite easy to build the controller. 2 single reservoir master cylinders, 2 turn buckles, and some scrap steel I had, was all I needed. I spent around $100.00 for the cylinders, turn buckles,and some brake line. There is a place in Vermont, I believe, that might have the original controller or maybe some parts. I think Paul Buhler gave me the phone # but I lost that also. gregjo1948
- Paul Buhler
I believe Lavoy has access to some of the original controller repair parts. I haven't found a consistent source that has used controls; as Lavoy said, they are hard to find. If someone finds one, it's worth picking up.
- RacinJason
8A Winch Controller
I have an 8A on my 420C, with no control. It has seen better days and has some massive welds on the top, to the mount. It runs in one direction when I engage to PTO, so I spooled a spare cable onto it. Unfortunately, it doesn't freespool very easily, so is very difficult to pull out by hand. I'm thinking of attaching the cable to a tree and pulling it out and rewinding a few times, to see if it will free up. Never know when it might come in handy, even if it only works one way.
JD 112, JD 420 C
Sounds like the 'auto pull out of the mud' option, and that can be *really* handy!
- Paul Buhler
- RacinJason
I have the aluminum controller housing. It is missing one of the end caps and there are no guts. Anyone want it just pay for shipping. gregjo1948
Please don't contact me about this controller housing. I am sending it to a JD Crawlers member. Thank you, gregjo1948gregjo1948 wrote:I have the aluminum controller housing. It is missing one of the end caps and there are no guts. Anyone want it just pay for shipping. gregjo1948
seeking gearmatic winch manual(s)
I have a 1954 JD40C 4-roller with Holt blade and a gearmatic winch..but winch is not operating/needs overhaul. It's an upcoming project.
I'd appreciate a copy of that manual, too, if available.
thanks!
thanks!
- Paul Buhler
Gearmatic Model 8 - disowned?
Paul, Thank you for sharing the 8A/8G manual. Using it, I was able to identify I have a Model 8A.
Now, does anyone know why the Paccar Gearmatic website, which lists all manner of Gearmatic Models, specifically excludes the Series 8 Winchdrums? Even their Gearmatic Performance Info for Older Style Winches skips over the Model 8s:
http://www.paccarwinch.com/pdf/LIT2354_8-2007.pdf
http://www.paccarwinch.com/manualsanddo ... ddocs.aspx
1954 JD40C with Holt Blade and Gearmatic Winchdrum Model 8A
1947 Ford 8N (yes a '47!)
Users browsing this forum: No registered users and 198 guests
