icd water pump pics
Post by Stan Disbrow » Mon Mar 16, 2015 12:39 pm
The thrust of blade angle wants to twist the blade frame to the right. So, there is a rub block for the frame to snug up against. On the 440, it is that bar noted. On the earlier machines, it is incorporated vertically on the LH side of the grille guard. ;)
johndeere4402-53
Post by johndeere4402-53 » Mon Mar 16, 2015 1:46 pm
whiteclipse16 wrote:That thing looks great. You need to start a thread in show and tell of all the progress.
I'm surprised how different your blower looks compared to mine.
Couple questions?
How did you get the hydraulic controls to be in the dash like on a gas 440?
In the last pic, what is the steel piece (2" tall x ~8" long) bolted near the grille? It's bolted under the ~12" x ~12" square that would say "440 Diesel"
The controls we got in a trade loader to blade. Those are rub rail i like them were also putting the ones on that go of the grille for like a loader but they make it look different. I might start a thread soon
whiteclipse16
Post by whiteclipse16 » Tue Mar 17, 2015 6:06 am
So since you're putting the alternator on, you not longer need the voltage regulator, so you are able to fit the hydraulic control in the dash?
Ben
johndeere4402-53
Post by johndeere4402-53 » Tue Mar 17, 2015 2:00 pm
whiteclipse16 wrote:So since you're putting the alternator on, you not longer need the voltage regulator, so you are able to fit the hydraulic control in the dash?
Or because i didnt have the factory generator....
johndeere4402-53
Post by johndeere4402-53 » Mon Apr 27, 2015 4:05 am
GaCatskinner
Post by GaCatskinner » Tue Sep 22, 2015 6:51 pm
What alternator is that and is there any update on your project?
johndeere4402-53
Post by johndeere4402-53 » Wed Sep 23, 2015 4:07 am
Its a small GM alternator 18 charging amps it was like 78 bucks. There is a resto thread in show n tell
