440 diesel 831 loader
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Mon Nov 17, 2014 1:27 pm
Are they supposed to be two electric oil pressure sending units on the left side of the 2 53 Detroit?
The wires are pretty hacked, cant trace them back to anything.
Also looking for a governor shield.
nothing crawles like a deere
Post by Lavoy » Mon Nov 17, 2014 7:50 pm
One is oil, other is temp I believe.
shinnery
Post by shinnery » Mon Nov 17, 2014 11:57 pm
One might be the pressure switch for the engine hour meter.
Post by jtrichard » Tue Nov 18, 2014 10:18 am
IF both are in the oil galley one should be dash gauge or light.... other one most likely hour meter switch as said above.....an hour meter switch would have 2 terminals ..light would have one and gauge most likely one also :) :)
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Tue Nov 18, 2014 12:34 pm
The hour meeter makes sence now i believe one does has two terminals.
whiteclipse16
Post by whiteclipse16 » Thu Nov 20, 2014 8:07 am
Yes one if the pressure switch for the hour meter and the other is for the electric gauge.
Water temp is at the top of the engine in the head. It's right in front of the bracket for the throttle rod (on a non-center throttle model).
Do you have any extra electric oil pressure gauges? Mine was trashed and I can't find a factory original anywhere. I think Lavoy is working on some reproduction ones.
Ben
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Thu Nov 20, 2014 5:57 pm
Whiteclipse that's the only one i have, if i decide not to use it i will let you know. Im not sure it even works
Im surprised you cant find one, i can take my switch to napa and and go threw there old books and try to get you there part number if you want.
I cant imagine that it was made just for Deere.
whiteclipse16
Post by whiteclipse16 » Fri Nov 21, 2014 11:07 am
I've found tons of them for the gas jobs.
Problem is mine was so bad that I didn't have a good part number off of it. I think they were made by stewart warner but I could be completely wrong on that.
Let me know what you can find as far as part numbers.
The diesel gauge is different from the gas as far as I know. It's electric for one and I'm pretty positive the face is different, it doesn't say Deere on it right?
Ben
Users browsing this forum: Google [Bot] and 388 guests
