350D isloator now available
Post by Lavoy » Wed Oct 22, 2014 8:04 am
Been working with one of you guys on the rubber torsional isolator for the later 350's. I now have a few available, $775 + freight. When these are gone, will be a several month delay to get more, but at least I have a few available.
Checking on flywheels right now to see if I can put together a conversion for the older crawlers.
cdunn
Post by cdunn » Wed Oct 22, 2014 6:39 pm
Lavoy, I would certainly be interested in one for a straight 350. Let us know when you come up with something.
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
Post by Lavoy » Wed Oct 22, 2014 8:12 pm
Check with a local salvage yard in case they have a used flywheel, I can get new ones, but pricey, and freight just adds to it.
Off the cuff guess, about $1500 for flywheel and isolator.
cdunn
Post by cdunn » Fri Oct 24, 2014 7:52 pm
I have a flywheel that came off a straight 350 which did not have a reverser. Would
it be what i need?
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
Post by Stan Disbrow » Sat Oct 25, 2014 5:46 am
No, straight 350s without reversers had a regular clutch and flywheel.
cdunn
Post by cdunn » Sat Oct 25, 2014 5:44 pm
My straight 350 with reverser has the isolater with the springs ect. and makes the typical noises. Lavoy mentioned for me to look for a salvage flywheel. Could you clearify which flywheel i need.
Sorry, i missed it somewhere.
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
