SPLITING TRACKS
FL450B
SPLITING TRACKS
Post by FL450B » Mon Jul 07, 2014 6:58 pm
MY 450B HAS BRECO AFTERMARKET CHAINS CANT FIND MASTER LINKS AS JD TRACKS CHAINS HAVE FOUND PIN WITH BUSHING AND PIN IN IT ANY ONE EVER SPLIT ONE OF THIS TYPE OF TRACKS
Labparamour
Post by Labparamour » Fri Jul 11, 2014 8:31 am
Not sure if you have been looking for the style master pin with a head and retainer clip or the dimpled pin.
I think Crawler123 has a great post on when he had to break his tracks.
I have the dimes style and torched out the end and hammer them out- there are posts that mention that procedure.
Not sure if that procedure would work on non-master, i.e. torch both ends out hollow and drive out.
FL450B
SPLITING TRACKS
Post by FL450B » Mon Jul 21, 2014 4:45 pm
OK SO I FOUND THE MASTER LINK PIN ALL THE PINS HAVE A DIMPLE ON MY AFTER MARKET CHAINS BUT ONE HAS A RAISED UP CENTER HARD TO FIND WITH SMALL AMOUNT OF HEAT AND A BIG PUNCH AND HAMMER AND I GOT THEM OUT LOTS OF YOU LOOKED AT THIS POST NOT MANY TAKES ON HOW TO REMOVE THEM THANKS I SURE I WILL FIND SOME OTHER ISSUE AS I DIG IN TO REPLACE STEERING CLUTCHES
Users browsing this forum: No registered users and 9 guests
