Waiting for the call
Post by Stan Disbrow » Mon May 19, 2014 2:45 pm
Joystick would be for a PAT. A PAT is usually seen on industrial machines. Manual A/T blades are more common on an Ag machine.
A manual blade just has lift, so one lever for that. The 3 pt would be another lever. A remote would be a third. So a 3 lever arrangement makes sense to me.
Post by jtrichard » Mon May 19, 2014 3:00 pm
if it is a early 1010 the ser.# tag is on the right side of the engine between the oil filter and the gen.
gus
Post by gus » Mon May 19, 2014 5:00 pm
It's a full hyd 6 way blade and there are 4 levers on the right fender... damn I wish I'd of thought to bring a camera yesterday!!
In the photos I've seen, I do not see 2 levers on the left side of the dash. I know one is PTO and I'm thinking the other is either the rear hyd or 3 pt. Or, one of the levers on the fender is the rear outlets/3 pt.???
It has the normal 4 spd shift and throttle on the right side of the dash.
Post by jtrichard » Mon May 19, 2014 6:13 pm
YES pics would be nice and help a lot
gus
Post by gus » Tue May 20, 2014 10:04 am
I would really like to know what the 2 levers on the left side of the dash control, anyone?? From the tag, one is the PTO, but the other??
Post by Stan Disbrow » Tue May 20, 2014 10:09 am
IIRC, if that was an Ag crawler with 3pt and no blade, then the 3pt hyd control is on the dash.
gus
Post by gus » Tue May 20, 2014 1:30 pm
Stan Disbrow wrote:Hi,
Thanks Stan,
From that, then the 4th lever on the fender is for the rear hyd outlets and the other 3 are for the blade.
