I have checked the pressures ans all seem to be in order except whenI shift into high range. Reverse and low are fine and hold enough push and pull hard. When shifted to high it will move then slow down and stop. I have been running with the gauge in the pressure port and it seems to vary fron 40 to 100 back and forth. When in high range.
I have been working on adjusting the clutch and probabley need to fine tune.????
My presure at start up is about 180-185 and will stay there even after an hour of running I only lose in high range. Any Ideas????
Was digging some basswood stumps tonight still foze under some of them.will spring ever come? Thanks
450b high range
450b high range
There is always another rock under this one!
450high range
Thanks Jt
I have been running it in low range so far was afraid I might screw it up to use high. Is it a big job to do these seals you talk of? I will be doing some more testing today. THanks
450high range
Thanks Jt
Users browsing this forum: No registered users and 242 guests
