I'm looking for a gasket for my john deere 450 crawler. JD said it is not available through JD anymore. DO you have an idea of where I can get one? The number is T20774. Tractor sn #T5E3M101119T I'm trying to rebuild my trans. thank you for your time.
Greg
Transmision Gasket
Buy gasket material at a parts or bearing house, it is available in many thicknesses, and cut your own. Or possibly use the blue stuff.
rock digger
trans gasket
The gasket was discontinued by deere long ago,they now use a loctite gasket compuond sold at many parts stores and by deere dealers, I am not sure of the number,but I used it recently on my 450b trans case seemed to seal just fine. Remeber to only tighten those bolts to 35ft.lbs or they can break. I could tell you all about that problem. If you can't find it I can get the number next time I am in my shop. Good Luck,
There is always another rock under this one!
It is current, $20, just subs to a different number.
