Gus: We have his and hers roof rakes and we share the beer; sometimes most of a six pack of 22 oz home brewsJust tell the wife to get you a beer first then get up on the roof and shovel it off... Holler when she's done and you'll put the ladder back up for her. Shocked Shocked Laughing Laughing
Anyone come up with a better way to get snow off the roof?
- Paul Buhler
That's the best thing for snow, too slippery for the stuff to hang around very long unless the slope is shallow. Standard shop roof is 3/12 pitch and stubborn snow might stick, my house is about 3.5/12 and the snow hangs out for a couple days then flows off, I'd imagine anything steeper than 4/12 will be impossible for snow to hang on to.Lu47Dan wrote:Go to steel roofing and than slam a door hard![]()
Dan.
Unfortunately it also becomes lethal to walk on!
- Paul Buhler
Unfortunately it also becomes lethal to walk on![/quote]
Nope, my roof is steel, 5/12 pitch and the snow slides off slowly making a huge curl which I bust off. That's a lot of weight on the eaves which in the front is a 6' overhang. I've not found a good way to get rid of it yet and it's too steep to walk on. Normally not a problem but every few years we'll get 2' of fairly heavy wet snow.
We live in the snow belt of Ontario and have several of the electric portable storms that are pictured I have one steel roof that has little pitch so it is the most snow collecting roof that I have just enough slope for self cleaning if I get heat in the attic of that side it will take several hours of warmer temps to get things too move but when it goes the hole house shakes after several roof cleanings we got an other foot or so of snow and I found Scott and several of his friends tobogganing off the top peek of the house hitting the snow pile at the ground that was just the right angle for the toboggan to continue into the back yard at a high rate of speed I had to kind of stop that as the toboggan was hitting the screws and loosening them He has since grown out of that but this winter you could drive the snowmobile up that roof right now (No giving him any ideas OK) .Digitup. .
- waterman28
Re: Anyone come up with a better way to get snow off the roo
look up the avalanche roof rake on youtube. Ibuilt one and it is the best system I have used. Really fast and was easy to build.
JD 1010 Crawler
Ferguson TO 30
Case 580C
996 David Brown
Ferguson TO 30
Case 580C
996 David Brown
