#63 manual angle blade ?
How do I angle the blade ? I pulled the pin where you adjust the angle but couldn't get it to move . Do I need to pull the pin where it pivots also or is it just stuck ? Trying to plow some snow here, thanks Jay
Pretty sure there is a pin on the right side and left side. Did you pull both pins? Won't move if there is a pin in both forward arms and you only remove 1.
440 ICD 64 blade & 8a gear attic winch
440 ICD 831 loader with scarifier and weights
420 62 blade 3pt
Looking for 24 scarifier and 440 log arch
420 62 blade 3pt
Pull the pin on the side you want to extend, and also pull the pin on the pivot piece on the blade, if you don't, you will break the casting.
I should have said break the casting, or bend the telescoping part of the arm, seen more than a few of them.
What the heck? I would ask how do they *do* that, but I have been around too long. I know there are no more clever folk than idiots. As in 'hey, I cant pull this arm out (or, push it back in). Where is that fat oak tree to pull (or push) with?'
