help!! need a starter for a 350b with diesel engine
Hello All, today my starter solenoid clicked and that's all it would do, so after checking voltage at starter and battery connections I pulled the starter out. I found the nose cone broken off and jammed against the flywheel teeth. I now need a new or reman starter because my core is junk. do any of you have a good part # that'll work? i'm trying to cross at a/c delco and everything is coming up obsolete?
starter
When the same thing happend to my oliver tractor starter I welded it back together, that was three yrs ago. Put the cone on and clamp it together and spot weld it. Then take off and finnish welding, I used a wire feed, You may get by until you find another. It worked for me. good luck, rock digger
There is always another rock under this one!
350 starter
D B electrical has new just over 100.00 just got one for my 302 three cylinder diesel. used them for alternator also on my 350
JIM
JIM
Replacement Starter
Thought I needed a new starter for my straight 350. I checked my local parts store ( Parts City ) and they could get me a replacement starter that would be identical to the OEM starter. No modification needed. Reasonable too !!! I was blessed that it was only the solenoid.... starts great now. Good luck with yours.
Fred
Fred
Users browsing this forum: Bing [Bot] and 32 guests
