Lifting out stumps causes a problem..
Scottyb
Post by Scottyb » Wed Oct 30, 2013 10:11 pm
All was going well on a nice day of pulling stumps....
then this happened....
backhoe attachment.
Post by jtrichard » Wed Oct 30, 2013 10:25 pm
doesn't that just make your day?? :cry: :cry:
Scottyb
Post by Scottyb » Wed Oct 30, 2013 10:38 pm
And to add, I remembered as soon as it came off, that, I never put the rock guards back on that side. Had that one off to do a small repair. :oops:
backhoe attachment.
Post by jtrichard » Wed Oct 30, 2013 11:43 pm
Shame on you.... didn't your mama teach you better than that?? :oops:
Scottyb
Post by Scottyb » Thu Oct 31, 2013 12:55 am
yes, yes she did. However I did one more stupid move before I got out of this mess. I put the loader all the way down to go for tools, and the loader frame jammed that track in tight against the nose. Double Damm! However, a half hour with the pry bars, backing off the track by letting out a big turd of grease, and the luck of having a winch on the back to drag myself back out of that stumphole.... all the while using a little reverse to keep the sprocket tight on the chain and quicker than a Magpie on a gut pile, I had it back on.
Called it a day and I am not telling mama.
backhoe attachment.
Post by jtrichard » Thu Oct 31, 2013 12:37 pm
not that you are in the US but is that pallet/rock guard/cable guard OSHA approved???? :) :) couple 4x4s and another pallet and you would have a ROPS :lol:
JWB Contracting
Recovery Unit
Post by JWB Contracting » Thu Oct 31, 2013 7:15 pm
I was thinking it was time to add a recovery unit to your collection.
A hoe equipped 450 will pack an entire 350 crawler into the shop for repairs.
Our yard 350 had a final drive go a few weeks ago, I'll take a picture as proof.
That's was a quick track re-install. Rock guards are an absolute must at all times if you are working these crawlers. Plus properly adjusted tracks as per the technical manual.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Scottyb
Post by Scottyb » Thu Oct 31, 2013 11:21 pm
Yes I got a bit lucky with that track install. It sure helped that I was just off a hard gravel trail and the winch pulled me easily back onto a solid level surface. As well, the bottom back few rollers stayed on the track. I discovered in the process that there is a fair bit of wobble in the front Idler. That might have contributed to it coming off. I had that stump up in the air backing out of the hole turning all the while. Rookie mistake. I have not put the expelled grease back into the adjuster yet, drove it back to the cabin loose as it was too cold for the grease gun to prime. I will be picking up new bolts for the rock guard tomorrow and will try to get it on before heading back to get that stump on the Weekend.(weather permitting) Many of the stumps I am pulling are in much worse places if it should happen again. It amazes me how large of a stump the 350's will lift. I have not found one that is too heavy. Spruce is not the heaviest wood though. Bad news to hear that final drive went, I assume you have spare parts?
backhoe attachment.
JWB Contracting
Final Drives in Stock
Post by JWB Contracting » Fri Nov 01, 2013 7:57 am
I haven't looked yet but 100% sure we have 3 or 4 in stock.
This machine was used only during the summer for loading pipe and stayed in a customers yard for over 15 years without only motor oil changes so I can't complain. I'm guessing we ran the final drive dry.
Just another winter project that will get put ahead of working on some of my collector units.
Jason Benesch
