hot brakes??
hot brakes??
I've been having steering issues lately. I'll adjust the clutches and brake bands on a 350 b and after about an hour or two of running you have to really reef on the levers to stop the track to steer and eventually it doesn't matter what you do you cant steer. The clutches are releasing fine, just the brake bands are not grabbing. Let it cool off and it will steer just fine again.
The brake bands only have about 75 hours on them, and it did not do this last year.
Any ideas?
Any ideas?
Is the engine pulling down while you are doing this? If so, remove some freeplay, that will probably help.
Odd, not sure what that would be.
I sort of wonder if you are observing brake band glazing, especially since it is occuring when hot? This could be a cause depending on the source of the brake material- not all brake material is created equally. If you don't know what glazing is, here is a simple definition from an automotive website I grabbed:
Brake pads contain various metals and minerals that are bound together using a resin. At high temperature, this resin turns to liquid and can bleed out onto the rotor. Glazing is dangerous because it prevents normal contact between the pad and the rotor so you lose pad bite.
Unfortunatley, to know if you have glazing you would need to be able to visually inspect the brake band.
That's what I was thinking. The gentleman that relined them when I had the finals apart is very good and did all of the clutches and brakes for my company. Sadly he's no longer with us or I'd ask what he used or if that is a possibility. Damn shame too, besides being a stand up guy he only charged ten bucks for a reline.
I do know that they were riveted to the bands not bonded.
Users browsing this forum: No registered users and 20 guests
