350b crawler dozer float position
Unclebeef
Post by Unclebeef » Thu Jun 27, 2013 9:28 pm
Hello All, i just purchased a new to me 1972 jd350b crawler dozer and i need some help. Does the dozer have a float position? I purchased the loader operators manual and the tractor operators manual from Deere but i cant seem to find anything mentioning a float position. Also it has a rear pto that spins when your in motion, i see in the manual it shows a pto lever by your feet near the pivot point for the steering controls, but i don't have a lever there? I still have to keep playing with it but thought some of you may have been down this road before. thanks for any help.
Post by jtrichard » Thu Jun 27, 2013 10:18 pm
it should have a float pos. the detent is probably broken or the linkage is so worn that your not getting the spool far enough to lock in float
Unclebeef
Post by Unclebeef » Thu Jun 27, 2013 11:00 pm
thanks for the quick reply, i'm going to go lube the chassis and pivots this weekend, i'll look over the linkage. Can you desribe how to get in float position? thanks for any help.
Post by jtrichard » Thu Jun 27, 2013 11:21 pm
push "T" handle as far forward as possible and it should lock if it dont ...push forward and lift front of crawler off the ground (not to high) and then push farther and the front should drop like a rock
Unclebeef
Post by Unclebeef » Thu Jun 27, 2013 11:46 pm
thanks, ill try it this weekend and see if I can get it to float. i appreciate the instruction.
Unclebeef
Post by Unclebeef » Thu Jun 27, 2013 11:49 pm
I forgot to ask you if you had any idea on the pto controls. how to stop and start the pto, any info is greatly appreciated.
Users browsing this forum: No registered users and 121 guests
