Clutch adjustment
ggfossen
Clutch adjustment
Post by ggfossen » Sat Sep 30, 2006 5:01 pm
The fingers of the new pressure plate/clutch that you sent me are protruding beyond the gauge limit about 1/16 or an 1/8. The adjustment nuts have a spring thing from between the nuts up and over the top.
To adjust, do I have to simply remove that spring? It doesn't appear to be necessary?
Did you get my email concerning the last shipment?
Gary Fossen
Post by Lavoy » Sat Sep 30, 2006 9:51 pm
Gary,
I thought I had pulled those tas off, sorry. Grab them with a pliers, not even sure what they put them on there for, I assume it is just an assembly aid.
Depends on which e-mail you mean, I have been gone since Wednesday. I have internet access, but no e-mail access. I will be home tomorrow and will catch up on e-mails.
ggfossen
Post by ggfossen » Sun Oct 01, 2006 7:41 am
OK on the tags.
Concerning my email to you, I got the wrong package. You may have to be home to access files to straighten it out?
Gary
Post by Lavoy » Sun Oct 01, 2006 2:36 pm
Gary,
Just got home 10 minutes ago, still playing catch up. Got your e-mail, I know where your stuff is at, I sent you an e-mail just now, sorry for the screw up.
ggfossen
Post by ggfossen » Sun Oct 01, 2006 5:51 pm
No problem. Whatever works best.
As long as I continue to find left over little parts on the bench, I won't be ready for the final button-up.
First, it was the lifters. I found those before the gasket glue had set up really tightly.
Now, it's a small ring that I suspect goes on the front of the cam shaft retaining the gear. At least, I hope so. If not, it goes into one of the finals, and I would have no way of knowing which one. They are both mounted, tracks and all.
My lack of organization is catching up with me.
Gary
Users browsing this forum: Majestic-12 [Bot] and 293 guests
