1010 fuel tank isolators
JimG
Post by JimG » Sun Mar 24, 2013 1:39 pm
Anyone know the thickness of the fuel tank isolators. Went to remove the fuel tank to clean and flush it and pop out a big dent and realized that nothing was holding the tank to the machine but the fuel lines.
Post by jtrichard » Sun Mar 24, 2013 11:52 pm
look at the radiator mounts they are the same as fuel tank mounts....form deere they are about $30 each (last ones i got from deere were junk broke in no time) when i got new ones for my 2010 rad (same ones as 1010) i got them from McMasterCarr i believe the part number is 9213K25 it is a better mount then JD and are $3 only thing you have to get new nuts (if you have the old ones) because the McMasterCarr ones are coarse thread JD are fine thread ...McMasterCarr also has a better one that made with silicone that have a much better temp and resistance ratting part # 4403K422 $9 each
JimG
Post by JimG » Mon Mar 25, 2013 8:13 am
Thanks JT. Gonna have to check my rad mounts also before I order. I was just going to sandwich a piece of rubber between the tank and mount with a through bolt but would rather do it right. Definitely wasn't paying what deere wanted for those things!
RanchTruck
Post by RanchTruck » Mon Apr 01, 2013 6:32 am
Check the radiator ones sooner rather than later. My uncle ended up spending a few hundred getting the radiator in his 1010 re-cored after it shifted back on a bump and the fan ate it. The stock bonded rubber mounts had separated just like your tank ones.
I re-designed the lower radiator mounts to be a welded pin set down through a rubber bushing in a hole like most other radiators use. That way the rubber could completely disappear and the radiator can't shift back into the fan.
Users browsing this forum: No registered users and 271 guests
