1010 fuel tank isolators
Anyone know the thickness of the fuel tank isolators. Went to remove the fuel tank to clean and flush it and pop out a big dent and realized that nothing was holding the tank to the machine but the fuel lines.
look at the radiator mounts they are the same as fuel tank mounts....form deere they are about $30 each (last ones i got from deere were junk broke in no time) when i got new ones for my 2010 rad (same ones as 1010) i got them from McMasterCarr i believe the part number is 9213K25 it is a better mount then JD and are $3 only thing you have to get new nuts (if you have the old ones) because the McMasterCarr ones are coarse thread JD are fine thread ...McMasterCarr also has a better one that made with silicone that have a much better temp and resistance ratting part # 4403K422 $9 each
Check the radiator ones sooner rather than later. My uncle ended up spending a few hundred getting the radiator in his 1010 re-cored after it shifted back on a bump and the fan ate it. The stock bonded rubber mounts had separated just like your tank ones.
I re-designed the lower radiator mounts to be a welded pin set down through a rubber bushing in a hole like most other radiators use. That way the rubber could completely disappear and the radiator can't shift back into the fan.
Users browsing this forum: No registered users and 257 guests
