Anybody know if there are different hydraulic pumps available for a 420; higher and lower volume???
I ask because mine was yellow, and it's on a green tractor?
Gary
Hydraulic pump question
OK. I think it was yellow, so it probably came off something from the factory that was yellow. I've found some of that odd primer (at least I think I have). This stuff is good old JD yellow, then red, then green. It's been around. Whatever it was, it's now new green.
Radiator, front weight, and hood is all I have left. Of course, the bottom brackets on the radiator are busted, so I will have to work by that, and the hood has it's share of small fractures. For that, I will have to learn more about welding.
So many hills, and so little time.
Thanks,
Gary
Thanks,
Gary
Users browsing this forum: Google [Bot] and 200 guests
