thermostat for JD 350C
Can someone tell me the correct thermostat for a 1978 JD 350C diesel dozer? Thanks.
its 205 temp http://jdpc.deere.com/jdpc/servlet/com. ... ervlet_Alt should get you to jd parts page you need
The NAPA THM530090 crosses from the JD number AT24013 BUT the 530090 is a 195.... AT24013 is 205... but a NAPA THM383 is a 205 same dia. also they all fit a 63 Chevy pickup
2010 uses the same size but it calls for a 180 all said i would think 195 or 205 should be fine for your threefitty
Re: thermostat for JD 350C
Just went to purchase this at my local NAPA store, here in Vancouver, and found out that NAPA.ca uses a different numbing system. If you need this item in Canada their part # is PM 195-0025
Users browsing this forum: No registered users and 266 guests
